G729 request
puddy
G729 request
Have been looking on the gradwell site and found this
By Default we support the G711a or G711u Codecs but if you are using multiple phones on your broadband connection, or you have a low bandwidth internet connection, then in the Audio Configuration section we recommend you choose G729a as the Preferred Codec. This will allow the phone to use less bandwidth where possible.
Please note that if you wish to use G729a you will need to request that this codec is enabled for your extension
Does the affect us on the beta trial and do we need to make a request?
puddy
1 REPLY
petermaughan
Re: G729 request
Hi puddy,
I don't know what the offical answer to this question is but I changed my SpeedTouch router to the G729 codec and found that it worked better, without making any request.
Peter
