Fring version 4 setup
kentishboy
I have been a fring fan for a while.
Having installed version 4.3.1.2 I find I need to manually add my plus voip account details to use SIP.  3 pieces of info are required user name, password and  proxy.  Please can you verify the proxy setting as I have found none to work so far.
Grin  Cheers
Fixes: 44
Re: Fring version 4 setup
I've never used fring myself but from the last post on this thread http://community.plus.net/forum/index.php/topic,58951.48.html
the settings seem to be
User Id      - 1234567@sip.plus.net:5060 (where "1234567" is your 7 digit extension number)
Password  - your password
Proxy        - natproxy.plus.net:5082
Hope that helps
kentishboy
Yes you are right !
With your help I have fring restored on my old Nokia e61I.
BTW I find that I can use the plus net VOIP simultaneously on  fring and SJPHONE on my PC.  I noticed that SJ Phone has at least 2 voip channels but I was unaware two devices could share a single VOIP extension. Cheesy
Richard
