Fring settings on WM6 smartphone
mickg6wci
Trying to get Fring / SIP to work on my Benq E72. Fring installed OK and test call worked a treat, most encouraging. Trying to set up SIP, which I use all the time with a WiFi phone, I am unable to complete the registration part. i.e. user name , password, and proxy. Reading through forum have found many different combinations of domain name and proxy addresses, all porporting to work, not for me. Is there a difinitive answer to this or does it vary with device?
Fixes: 41
Re: Fring settings on WM6 smartphone
Looking at this http://www.gradwell.com/support/kb/article.php?id=14 configuration guide for Fring using Gradwell and attempting translation to PlusNet voip settings I would suggest as follows:-
Username - xxxxxxx@sip.plus.net ( where xxxxxxx is your 7 digit SIP ID )
Password - your Sip password
Proxy - natproxy.plus.net:5082
Let us know how that goes.
mickg6wci
Thanks for the reply, have actually got it going now, thought to check my WiFi phone settings and realised I had my ID wrong. i was using the full EXT number but my id is only 6 digits long.
