Fring for iPhone guide
ramidoodle
Do you use Truphone on iPhone?
Why not using your PlusNet Broadband VOIP minutes to save some money! Give Fring a go on your iPhone Smiley
it doesn't cost you a penny, you have your included VOIP minutes, people can call you to your mobile using your VOIP geographical number as long as you phone is online!
Setup insturction:
1. download and install Fring
    A. Easy way: using App store.
    B. Get it by sms, go to Voip Portal and you will get a text with a link (not sure if it will work with iPhone).
2. Follow the instruction,highlighted in red, within the attached and you're ready to start using Fring SIP dialer.
