Fring and Zoom adapter
zpeterk
I have a Zoom voip adapter that works fine but if I turn Fring on on my mobile the zoom adapter doesn't ring anymore. Is this supposed to happen?
1 REPLY
Fixes: 32
Re: Fring and Zoom adapter
I'm sorry for the delayed response. Initial answer is that It sounds like that may be supposed to happen. However I'll look into to it to make sure and get back to you ASAP.
Adam
 Adam Walker
