Flexor 500 help please
paiger
I've had a flexor 500 for a while now. Had a go at setting it up some months ago but even plusnet tech support could not get it going. I now really need this second phone  and I am aware that others have got it going. I plug it all in and it runs through Ethernet, LAN, Internet OK so all I need to do is configure it. I can get to the config account page.
Could anyone who has got this phone to work run through what they put in the account boxes? I can't even seem to find my SIP code / Username any more. I'm a total beginner at this and am struggling to get this going.  Many of the boxes do not correspond to anything in plusnet setup guide.
Help would be much appreciated.
Fixes: 41
Re: Flexor 500 help please
Here's a setup guide for the Flexor 500 although not for Plusnet. http://www.voiptalk.org/products/camrivox-flexor-500-voip-phone-setup.html
For Plusnet settings:-
On the first screen:
Sip Registrar:- sip.plus.net
Sip Port:- 5060
Sip Outbound Proxy:- natproxy.plus.net
Sip Outbound Proxy port :- 5082
The rest as per example
On the second screen:-
Service provider:- select Plusnet
Username:- your sip id
Authname:- your sip id
Password:-you sip password
Your name:- anything you like ( suggest your allocated number )
Everything else as example for now.
You got your sip id and password in an email when your account was activated.
Hope that helps
Ian
paiger
Thanks Ian, I won't get a chance to try this until Thursday now. Will let you know what happens!
Steve
paiger
Fantastic, worked a treat. Thanks so much for your help Ian, much appreciated.
Steve
Fixes: 41
Excellent!, glad I could help. Smiley
