Failed to register Sjphone
Evilgenius
Hi.
I cant get this SJphone thing to connect. The username and password Ive used doesnt seem to be correct. Can you guys forward me my Sip id / password so that I can try this out?
kind regards
Dave.
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: Failed to register Sjphone
Hi Dave,
I've just replied to your PM, you should have an email to the address we hold for you shortly.
 Chris Parr
 Plusnet Staff
Evilgenius
thanks chris. Didnt think the PM was sent, but it was.
Smiley
Evilgenius
Okay im still having problems with this. What exactly should a sip number look like and where on the VOIP control panel would it be? When initializing the Sjphone app, it asks for a user name and password. I have entered the one which was sent to my wifes inbox but this does not work.
o.coyle@xxx.com
the 8 character password.
I would edit the email address to disguise it. It is not a good idea to post personal details on the forum.
Evilgenius
k thanks.
Okay ive followed the instructions on the plus site for entering the details. Then ive added my SIP id and password. The error message i get is:
plusnet voip
service unavailable
authentication failed.
any ideas?
RichSmol
I've tested your account and it registered first time and i was able to make a test call to my own phone. I've PM'd the details you need to use so hopefully its just a matter of ensuring your authenticating with the right details.
cheers
Rich
Evilgenius
thanks Rich for your help.
Wink
