Extension PIN
Fixes: 8
Extension PIN
On the Broadband Phone Control Panel login page there is an option to login as extension where you enter the extension number and PIN. Where do you set the PIN for an extension?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
itsme
Re: Extension PIN
It's the Voicemail pin.
Fixes: 8
Re: Extension PIN
