Draytek 2820vn Settings Please
jorvikmik
I have been unable to get the draytek 2820vn set up, but voip using csip simple on wifi phone is working ok
1 REPLY
Fixes: 41
Re: Draytek 2820vn Settings Please
This thread http://community.plus.net/forum/index.php/topic,76564.0.html is a bit old but might be useful. It seems to imply from the settings posted there that you don't configure it for an outbound proxy, probably doesn't need it since the sip client is integrated on the 2820vn and so may not be behind a NAT firewall.
Let us know if that was any use...
