Down times?
Neo
Down times?
I have been monitoring my ATA's system log (using a small utility I created) and have noticed that registration will fail from time to time. Sometimes it will be just for a few minutes, but other times it can be for longer and the connection drops don't seem to happen at regular intervals (so I don't believe it is related to the 60 minute registration interval).
08/04/2008 10:44:27> SIP Registration succeeded for Line 0 at timestamp 1556949
08/04/2008 10:43:26> Terminate the register-client due to failure for Line 0
08/04/2008 10:43:26> Terminate the register-client - Re-Reg Request failed for Line 0 for reason -12
08/04/2008 10:43:26> Registration Retry for Line 0 after 60 seconds
08/04/2008 10:41:54> Terminate the register-client due to failure for Line 0
08/04/2008 10:41:54> Terminate the register-client - Re-Reg Request failed for Line 0 for reason -12
08/04/2008 10:41:54> Registration Retry for Line 0 after 60 seconds
08/04/2008 10:40:22> Terminate the register-client due to failure for Line 0
08/04/2008 10:40:22> Terminate the register-client - Re-Reg Request failed for Line 0 for reason -12
08/04/2008 10:40:22> Registration Retry for Line 0 after 60 seconds
08/04/2008 10:38:50> Terminate the register-client due to failure for Line 0
08/04/2008 10:38:50> Terminate the register-client - Re-Reg Request failed for Line 0 for reason -12
08/04/2008 10:38:50> Registration Retry for Line 0 after 60 seconds
08/04/2008 10:37:18> Terminate the register-client due to failure for Line 0
08/04/2008 10:37:18> Terminate the register-client - Re-Reg Request failed for Line 0 for reason -12
08/04/2008 10:37:18> Registration Retry for Line 0 after 60 seconds
08/04/2008 10:35:46> Terminate the register-client due to failure for Line 0
08/04/2008 10:35:46> Terminate the register-client - Re-Reg Request failed for Line 0 for reason -12
08/04/2008 10:35:46> Registration Retry for Line 0 after 60 seconds
08/04/2008 10:34:14> Terminate the register-client due to failure for Line 0
08/04/2008 10:34:14> Terminate the register-client - Re-Reg Request failed for Line 0 for reason -12
08/04/2008 10:34:14> Registration Retry for Line 0 after 60 seconds
08/04/2008 10:32:42> Terminate the register-client due to failure for Line 0
08/04/2008 10:32:42> Terminate the register-client - Re-Reg Request failed for Line 0 for reason -12
08/04/2008 10:32:42> Registration Retry for Line 0 after 60 seconds
08/04/2008 10:31:10> Terminate the register-client due to failure for Line 0
08/04/2008 10:31:10> Terminate the register-client - Re-Reg Request failed for Line 0 for reason -12
08/04/2008 10:31:10> Registration Retry for Line 0 after 60 seconds
08/04/2008 10:30:10> SIP Registration succeeded for Line 0 at timestamp 700177
Is anyone else seeing this? This is on sip.plus.net, by the way.
Is this behaviour due to blips on the PlusNet server or something else? The only reference to this error message I have found on the Net is down to a VoIP provider's registration proxy server having problems.
fotobits
Re: Down times?
Yes, Neo, I have noticed this, too.  The latest period was yesterday morning, 5 August.
I have only recently enabled my adapter settings to re-register automatically after a power-failure or after an adsl line-drop and, therefore, I have been monitoring the VoIP connection carefully.
No reference has been made to these "blips" on the Status pages and on the odd occasion I have raised the issue by a Ticket, the response has been that the service is operating normally.  I have assumed, therefore, that the problem is at the Gradwell end and it's not being reported.
Regards.....Noel
fotobits
Re: Down times?
......sorry, I meant the 4 August, which is as shown in your log!
Regards......Noel
ceridwen
Re: Down times?
That might explain why dialling out seemed a bit temperamental yesterday morning!
Matthew
Neo
Re: Down times?
Thank you for your replies, fotobits and ceridwen - I'm glad that this confirms that it's not just me Smiley I suspect most people wouldn't notice unless they tried call out at the specific time there was a blip.
[quote=fotobits]No reference has been made to these "blips" on the Status pages and on the odd occasion I have raised the issue by a Ticket, the response has been that the service is operating normally.  I have assumed, therefore, that the problem is at the Gradwell end and it's not being reported.One would have hoped that PlusNet or Gradwell were monitoring their system Undecided . Perhaps Gradwell need to look at employing a backup registration proxy server?
pd
Re: Down times?
Quote from: Neo
I have noticed some problems of late but they are not just affecting plusnet but appear to be DNS related.  I've just checked my log for yesterday and don't see any problems to match the times you mention but I did have a registration timeout at around 12:17.
Peter
