Double ring tone on outgoing calls
knowdice
Would be interested to know if anybody on here is seeing the same.
When I dial an external PSTN number in most instances I hear a double ring tone, UK and US superimposed on each other.
I'm using Gradwell direct but seeing as they supply the VOIP service to Plusnet thought I would ask here.
Gradwell support say it's the phone, but I suspect that one tone is the phone and the other is "in-band" from Gradwell.
Thoughts and suggestions gratefully received  Roll eyes
Fixes: 8
Re: Double ring tone on outgoing calls
What phone are you using?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
knowdice
Cisco 7975 & 7960 also Gigaset N300
