Does the Service work behind NAT Router
BrianDun1
I am awaiting my VoIP details after activation and was just wondering if there are issues when using an AYC PBX behind a NAT router for this service?
Has anyone had any problems or issues with using a VoIP PBX with this service?
Many thanks
Fixes: 44
Re: Does the Service work behind NAT Router
There are a few people on the forum using Asterix with some success, although there have been some minor issues in the past. Take a look at some earlier posts for e.g http://community.plus.net/forum/index.php/topic,69847.0.html
I've no experience of the AYC PBX, but  as long as you can configure your PBX to use the outbound proxy then you should be ok behind a NAT router.
Simon_M
The setup guide at http://www.voiptalk.org/products/ayc_setup seems to suggest that you should only use it from behind a NAT router.
That doesn't mean that there won't be any NAT related problems though.
Good luck!
