Does SJphone work with Mac powerbook ?
peaceplay
Huh  Iran SJphone on my old MK i iMac and then my old eMac but it will not perform at all on my powerbook. I don't think I did any thing different an I have checked the  setup. Angry
Fixes: 113
Re: Does SJphone work with Mac powerbook ?
it should do, i've used it on my MBP.
there's a library article here http://community.plus.net/library/voip/softphone-for-mac-os-x/ about setting up zoiper
Will Moderate For Thanks
peaceplay
Zolper functions. non function
  Zolper was simple to install on the powerbook, thanks, but seems to behave in a similar way to SJ phone. I dial and the display informs , STATE : dialing. but this always times out after 30 seconds and then I get the message:
'recovery on timer expire.'
The difference with SJ phone was that the prog never got further then attempting to contact proxy, and that stage never timed out.
  I'm wondering if the broadband phone is no longer enabled in my account !
peaceplay
  My broadband account seems to be activated, with some credit on there, but it just won't work.  I have a message on there about a password which does met security policy but when I follow link I get invalid page request.
