Do we keep our Local Number after the trial
teldanet
After the trial is over do we keep our current local number.
PS What was the number for the speaking clock, I have deleted my email
puddy
Re: Do we keep our Local Number after the trial
Yes we do keep our numbers
speaking clock number is 123
Puddy
teldanet
Thank you.
A question re your Grandstream GXP2000.  When I used a STUN server as suggested by Sipgate and PlusTalk in the configuration of this IP phone the phone worked fine for about a day then the phone's operating system used to hang and knock itself off the network.  Only a reboot would bring it back.  Now I do not use a STUN sever the phone operates for ever.  Have you any experience of this.  My softphone Express Talk works always no matter what.  I should add that I use a static IP address now which I didnt use before.
Bill
puddy
On the plusnet (trial) you should never use a stun server setting at all (hardware phone)and I have always used a static IP address it came with my BB account.
Puddy
Equipment used/help offered
Grandstram GXP2000
Siemens 460ip dect
Linksys PAP2-NA
Linksys SPA3000 uk spec
Speedtouch 716wlv5
[Moderator's note by Jonathan (chillypenguin):  Full quote of preceding post removed as per the forum rules ]
fredor
Quote from: puddy
Puddy
My ATA (Grandstream 386?) is set up with 'stun.xten.net' as the stun server and everything seems to work fine.
I just made the changes to USERNAME, SIP ID, SIP Domain, SIP Proxy etc as recommended by PlusNet.
Having said that I have only used it for local and International calls and not to other SIP clients.
