Do u use a Sipura/Linksys SPA 3000/3102/etc? Pls send configuration
golly
Hello,
Please heeeeelp!!!  After days of effort I've managed to get VOIP/Broadband phone working well but am no longer able to receive PSTN calls ie calls to my non-voip number (plugged in to the ATA) - the phone doesn't even ring.
Aim:  To use the same phone for BOTH PSTN and VOIP calls.  This means that the same phone needs to ring when either my PSTN number or VOIP number is dialled by a caller.  The dial plan should sort out the outgoing calls.
(Edited?) screen dumps may be the easiest for you if you have a working configuration to send.
Thanks,
Gol.
Fixes: 44
Re: Do u use a Sipura/Linksys SPA 3000/3102/etc? Pls send configuration
Hi and welcome to the forums,
I don't have an SPA 3102 myself but have you seen this thread http://forums.whirlpool.net.au/forum-replies-archive.cfm/918374.html
and the pdf http://www.jmgtechnology.com.au/spa_3102_guide.pdf it refres to in the second post.
golly
Thank you MisterW - much apreciated.  It hasn't quite solved the problem yet for a number of reasons but it has helped to narrow it all down a bit.
Again, much appreciated.
