Dial tone & calling local numbers on Linksys PAP2
lilypenny
I have to say after a few teething problems which took me about an hour or so to sort out when first installed the PAP2 it is working really well and am well pleased with it.
I have two questions, my dial tone bleeps fast for about 3 seconds and then goes to a standard tone, is this something in the settings that needs adjusting?
And when I make a local call within my own exchange area  I get an obsolete tone unless I dial the full area code first.
Anyone any ideas on these or is it normal? Cheesy
itsme
Re: Dial tone & calling local numbers on Linksys PAP2
The fast bleeps before the dial tone is an indication that you have voice mail. You need to dial *1 or log on to your account at http://voip.plus.net
It's normal to dial the full telephone number when using VoIP, in fact some VoIP supplier you have to dial the full international number.
puddy
 i agree you do have to include the STD code when making all calls
For more info you could look at www.gradwell.com they have more info on the linksys PAP2 adapter.
puddy
ps I have the full uk dialing plan and setup to turn the pap2 adapter to work with the UK telephone network just e-mail me if you want them
lilypenny
Thanks both, for your replies, I have checked and I don't have any voicemails, so sadly that can't be the answer, I have checked the Gradwell site, although it contains some useful tips it is sadly not a detailed resourse, but presumably will become more so as people use it and ask further questions.
I will e-mail you puddy for the Uk Dialling Plan.
Cheers
I have just recently signed up for Voip beta and also have a pap2 so please let me know if you come across some working settings.
To be fair my exisiting account works without many problems but it would appear that this is the way things are heading regardless  Smiley
puddy
UK Settings for Linksys PAP2 Device
Line Enable:  yes
sip port :5060
proxy :sip2.plus.net                  Register: Yes
Make Call Without Reg: No       Register Expires: 3600
Ans Call Without Reg  :  No
Display Name: sip  id number    User ID: sip id number
Password: sip password           Use Auth ID: Yes
Auth ID: sip id number
Audio Configuration
Preferred Codec:G7LLu            Silence Supp Enable: no
Use Pref Codec Only:No           FAX CED Detect Enable:No
DTMF Tx Method: INFO
Line 1  Advance Settings
Proxy and Registration
Outbound Proxy:nat.plus.net:5082
save settings
United Kingdom Regional Settings
Dial tone: 350@-19,440@-22;10(*/0/1+2)
Ring back: 400@-20,450@-20;*(.4/.2/1+2,.4/2/1+2)
Busy tone: 400@-20;10(.375/.375/1)
Reorder tone: 400@-20;10(*/0/1)
SIT 1 tone: 950@-16,1400@-16,1800@-16;20(.330/0/1,.330/0/2,.330/0/3,0/1/0)
MWI dial tone: 350@-19,440@-22;10(.75/.75/1+2)
CWT1 cadence: 30(.1/2)
CWT2 cadence: 30(.25/.25,.25/.25,.25/5)
CWT frequency: 400@-10
Ring 1 cadence: 60(.4/.2,.4/2)
Ring 2 cadence (BT Call Sign): 60(1/2)
Ring 3 cadence (BT Ring Back): 60(.25/.25,.25/.25,.25/1.75)
Ring 4 cadence: 60(.4/ .8 close commer if i do it I get a smiley face
Ring 5 cadence: 60(2/4)
Time Zone: GMT
FXS Port Impedance: 370+620||310nF
Caller ID Method: ETSI FSK With PR(UK)
Daylight Saving Rule: start=3/-1/7/2:0:0;end=10/-1/7/2:0:0;save=1:0:
UK dial plan
this will change problems when dialing number
( *x. | **x. | 0xxx xxx xxx. | 186 xxx xxxx | [1-8]xx | [1-8]xxx | [1-9]xx xxxx | 00 xxxxx x. | 141 0 x. | 1470 0 x. )
Some of my eqiupment gives me 3 sets of rapid tones too including my Siemens 460ip dect but not my Grandstream GXP 2000
puddy
