Control panel broken
zpeterk
When you go to the BBP control panel this morning it is showing loads of script
Fixes: 44
Re: Control panel broken
Yep, same here!
Fixes: 117
And here. Maybe we've entered the matrix..
Will Moderate For Thanks
Plusnet Staff
Plusnet Staff
Fixes: 159
Yeah, i get exactly the same here. I'll get someone to look into it and raise this.
 Chris Parr
 Plusnet Staff
paxy
... and for me ...
Plusnet Staff
Plusnet Staff
Fixes: 159
Raised with Gradwell and there is a service status out here: http://usertools.plus.net/status/archive/1255684247.htm
 Chris Parr
 Plusnet Staff
paxy
Seems to be fixed now (but a little different form how I remember it?!)
Plusnet Staff
Plusnet Staff
Fixes: 159
Yeah it looks as though the CSS has changed on there so the layout looks a bit odd, we'll raise that now.
 Chris Parr
 Plusnet Staff
