Configure X-Lite to check voicemail?
trdavies
Hi all,
Just got X-Lite configured and it's working very well so far, I'm impressed.  I've noticed that there's an option on the SIP account settings to make it check for voicemail automatically, does anyone know if this is supported by the Gradwell VoIP platform?  I know you can receive email notifications and dial voicemail manually on *1 or 185 but it would be handy if I could get X-Lite to check automatically when it signs in and notify me in the dialling display.
Smiley
1 REPLY
itsme
Re: Configure X-Lite to check voicemail?
Probably. I get a flashing light on my adapter when there is a voicemail. One way to find out is to enable the option and then leave a message and see what happens.
