Config Cisco 7960
mcgurka
Config Cisco 7960
Anybody any ideas on how to configure this device for plustalk?
Its running the SIP firmware.
Scott
RichSmol
Re: Config Cisco 7960
This looks like a great link! Looks pretty heavyweight so let me know how you get on...
http://www.asteriskguru.com/tutorials/cisco_7960_ip_phone_configuration.html
SouthernNetwork
I have just changed my 7960 from the old Plusnet service to the new Broadband Phone service, which goes live 1st May
The only real difference is that you have a different address for the outbound proxy.
So the config should look like this :-
In SIP configuration:
VOIP Control Port = 5060 (may be Default ?)
Register with Proxy = YES
Outbound Proxy - nat.plus.net
Outbound Proxy Port = 5082
NAT Enabled = YES
NAT Address = your phones inside LAN address e.g. 192.168.1.2
Line 1 configuration:
  Name = SIP ID
  Shortname = anything to identify the line
  Authentication Name = SIP ID
  Authentication Password = SIP Password
  Proxy Address = sip2.plus.net
  Proxy Port = 5060
all other settings should be default
This should get you registered ..
Steve W
Southern Network Services Ltd.
Steve@southernnetworks.co.uk
