Cisco ATA 186 config
neilh
Does anyone have advice/a working config file for a Cisco ATA 186 -> sip.plus.net ?
I see from the archives somebody called Liam got this to work in 2005...    But no details of how !
I have the unit running the latest SIP image and I get dialtone; just don't know how to set the parameters for a connection and the usual fiddling is getting me nowhere.  I know my ip, cisco, but new to Voice...
If anyone wants to take some wild guesses, the UIF asks for :
GkOrProxy:
LoginID0:  [ok, I've got this one]
AltGk:
AltGkTimeOut:
SIPRegInterval:
MaxRedirect:
SIPRegOn:
NATIP:
SIPPort:
MediaPort:
OutBoundProxy:
NatServer:
NatTimer:
MsgRetryLimits:
SessionTimer:
SessionInterval:
MinSessionInterval:
DisplayName0:
Fixes: 44
Re: Cisco ATA 186 config
Ok I don't have one but looking at the manual here's my first guess.
GkOrProxy: sip.plus.net
UID0: <your 7 digit sip id>
PWD0: <your sip password>
UseSip: 1
SIPRegOn: 1
OutBoundProxy: natproxy.plus.net:5082
DisplayName0: <anything>
Everything else you can leave at default I think.
Let us know how that goes...
neilh
Thanks MisterW, I'm getting somewhere... when I switch SIPRegOn: 1, I lose the dialtone.  So it's failing to register I guess.
I've set up debugging and I get the log (below).   The first thing that looks wrong to me is the "realm", but I don't see this as a configurable parameter...
[log deleted - see later post]
Fixes: 44
Fisrt thing you might want to blank out the public IP address and your sip id from the log , this is a public forum!
quote]The first thing that looks wrong to me is the "realm", but I don't see this as a configurable parameter...
No, the realm (newsip) is fine, that is sent by the Plusnet end and the 186 is correctly returning it.
The register sequence looks reasonable to me , Are you sure you have the correct password ? remember its the 'sip' password NOT the one you use to login to the voip portal.
neilh
Password is correct but you've set me thinking and I've resolved it.
There is both a UID and a LoginID; I had it set to use LoginID, which is wrong.  I must have switched that on when I was blundering in the dark earlier.
Making calls now, thanks very much for your help !
Fixes: 44
Glad you got it working.
