Cannot Dial Some Numbers
I'm getting "Not available" from my Siemens AP580IP and "Call failed: No route to call target" from X-Lite when dialling some numbers this morning.
Some numbers are working but others (including 0114 296 5188 - PlusNet Support) are not. The numbers that don't work are working from my landline. There doesn't seem to be any pattern to which numbers fail and which succeed.
Bob
James
Re: Cannot Dial Some Numbers
Hi Bob,
We're seeng similar problems from the office connection.
I've got one of the CSC guys dial testing from one of our test lines and we'll raise it with Gradwell if it's still an issue.
Ok - if you need another number that isn't working then try 0113 3809574 - Halifax Telephone Banking.
Very frustrating !
Bob
Seems to be working now.
Bob
Please could we have some feedback on what the problem and the fix was.
Bob
James
Sorry Bob - We had the same problem initially and before we'd managed to raise a fault report to Gradwell, everything started working again properly.
It's possible that they saw an issue and had it fixed.  Hopefully everything's now okay for you.
