Can you make or receive video calls on Plusnet
puddy
I am having a play with a Grandstream GXV3005 video phone, but noticed I cannot send or receive video calls on my Plusnet VOIP number.
I am using my sip number = xxx@sip.plus.net is this correct?
Do Gradwell or plusnet block voip video calls?
It works great on my Orbtalk and Sipgate accounts
puddy
1 REPLY
Fixes: 41
Re: Can you make or receive video calls on Plusnet
puddy,
A quick google for 'video call gradwell' throws up this https://portal.gradwell.net/support.php/knowledgebase/view/article_id/422 on the Gradwell support site
which contains the line 'Video Codecs: Ensure that no codes are listed under Enabled, Video is not supported on the gradwell network'
My guess is that video isn't possible.
