Can make 123/160 calls, not 01/02 etc
mykejb
I've got my router set up with the new trial settings and I can make 123 and 160 calls without a problem. If I try to dial any 01/02 number I get an engaged tone. If I try to call my geographic number I go straight to voicemail.
The website at voip.plus.net thinks I'm not registered even though I can make the 123/160 calls. I have the expiry time set to 20 seconds so I don't think it's getting dropped out.
I figure I'm missing something but not sure what - anyone have any ideas?
Mike
prichardson
Re: Can make 123/160 calls, not 01/02 etc
I have recently had this issue with my Nokia E65, were I got exactly what you are seeing, though it would occasionally as registered.
It depends on what software/hardware you are using as to what to check, but on the E65, it was because I had my SIP number down in some setting, when I should have had the full 1234567@sip2.plus.net there.
This may be worthwhile checking.
mykejb
I tried a few changes and turns out the phone number field has to be the SIP number, not the 0116 geographical number so seems like it's working ok now Smiley
I see we get CLI on calls from the VOIP service now - BIG improvement !!
Mike
