Can anyone recommend a VoIP Adapter?
fotobits
Can anyone recommend a VoIP Adapter that when connected to a telephone base-station controlling four analogue 'phones, provides :-
a) both a PSTN connection and a SIP connection, selected at the handset by entry of a code and
b) the Caller Display feature?
I would like it to include straight forward set up instructions and, if it is likely to be necessary, a help-desk that speaks English and knows the product!
For several years, I have used a Zyxel P2002, however, this Adapter does not enable the Caller Display feature.
Regards......
zpeterk
Re: Can anyone recommend a VoIP Adapter?
I have a Zoom 5800 been good for three years and call quality is excellent.
The instructions are rubbish and there are features that don't work but it would do what you want.
There is an old thread with my ordeal setting it up but if you aren't new to it it should be OK
fotobits
Many thanks for your response zpeterk.  I'll look at the features.
Regards......
