Can anyone help Please - Siemens Gigaset C475
mkiyani
With the forum support and after lot of struggle finally I did registered my siemens C475.
But now Unfortunately my internet is disconnecting every few minutes and if I place a call through C475 my router resets every time automatically. If I take out the ethernet cable of C475 from the router then internet works perfectly.
        My router is Thompson. Network provider Plus Net. I am using only wireless connection for two laptops. No other devise is attached to my router.
        I have tried different ports of the router for voip connection, the problem remains the same.
 I will be very greatful if someone can help me out please.
Fixes: 44
Re: Can anyone help Please - Siemens Gigaset C475
Sounds like the router may be faulty if its crashing, Have you tried upgrading to the latest f/w here http://community.plus.net/library/hardware/how-to-upgradedowngrade-the-firmware-on-the-thomson-585v7...
mkiyani
thank You MisterW for advise.
I have checked My router firmware which is 8.2.23.0.
I do think I need to upgrade this.
Regarding the link You sent Can You kindly let me know how to open that bin file and if the 8.2.6.5 (plus net branded) will be the one for upgrade.
          thanks.
Fixes: 44
I dont actually have one of the PlusNet TG585v7 routers but my guess would be that the 8.2.6.5 PlusNet branded is the one to use for upgrade.
You open the bin file with the Firmware flashing utility as described in the instructions.
mkiyani
many thanks, its in process of downloading. I will update You if this works
mkiyani
Thank You MIsterW very much.
looks like, it did work.
Currently no more disconnections.  Hope it stays like this.
      Have a nice a peaceful day.
Fixes: 44
Sounds good. Smiley
puddy
To make life easy with your Thomson router and gigaset ip voip phone to tick always use the same address
See link below
Kind regards
Puddy
mkiyani
Thank You Puddy for kind advise. I will do that.
          Thanx
