Can Calls Be Encrypted (BB Phone/X-Lite)
Phil7979
I've noticed that my calls on broadband phone (using X-Lite v3) are not encrypted (as indicated by the open padlock on X-Lite)
Is there anyway of turning on encryption on X-Lite and BB Phone.
Thanks.
RichSmol
Re: Can Calls Be Encrypted (BB Phone/X-Lite)
I think you would need to enable a VPN client before doing so and eventhen you'd need to ensure that the VPN client isnt 'inspecting' the traffic in great lengths otherwise you'll suffer from lag and your audio will chop up. Might be some software out there which is a simplified version of a VPN client to do this job specifically though.
This solution seems to of been splashed about a bit in press releases:
http://zfoneproject.com/getstarted.html
Phil7979
Thanks Rich. I'll take a look.
