Camrivox Flexor 151 Configuration
DavidButler
I have purchased a flexor 151 ATA from Gradwell but have not been able to get the configuration set up.
Can anyone assist?
It ask for the following:
User name: I assume this is my PlusNet SIP user name
Password: my SIP password
Sip Registrar: ?
SIP Registrar Port:5060
SIP Proxy: nat.plus.net (is this correct)
Sip Proxy Port: 5060
STUN Server:?
STUN Server Port:?
Map SDP only: ?
Should I also set up any rules on my Netgear Router?
Any help and guidance welcomed.
Thanks david
itsme
Re: Camrivox Flexor 151 Configuration
User name: I assume this is my PlusNet SIP user name Yes
Password: my SIP password Yes
Sip Registrar: ?sip2.plus.net
SIP Registrar Port:5060 yes
SIP Proxy: nat.plus.net (is this correct) yes
Sip Proxy Port: 5060 no 5082
STUN Server:? leave blank
STUN Server Port:? leave
Map SDP only: ? leave
On the router set a rule for port 5060
DavidButler
Thanks for the response I will try these settings
Regards
