Caller Display not working on Linksys PAP2 Adapter
lilypenny
I have a Linksys PAP2 adapter and it always used to show the Caller Display number, but seems to have stopped, I have checked the settings in the Regional Options and it is set as follows:-
Caller ID Method is:- ETSI FSK with PR (UK)
Caller ID FSK Standard is Bell 202
I have tried changing the to V.23 but this makes no difference, is anyone else experiencing the same problem or does anyone know if they are the right settings?
1 REPLY
pd
Re: Caller Display not working on Linksys PAP2 Adapter
I use those same settings with no problem.
