Call failed: busy here - using X-Lite
mooer
I haven't used my Broadband phone for a while and tried several times today without success.  I can make the initial outgoing call and I hear the ringing tone at the other end for a split second, and then the line drops and X-Lite reports "Call failed: busy here".
*update* - Incoming calls work fine.
Help!
Amanda
mooer
Re: Call failed: busy here - using X-Lite
Well, curiouser and curiouser, it is working fine this morning.  Just one of those things i guess....
Amanda
Fixes: 41
AFAIK "Call failed: busy here" from XLite just means that the called number is Busy.
I'm not sure, but what MIGHT be happening is that the PLUSNET  SIP server is replying to your call with a 'Ringing' message when it connects you to the PSTN gateway and then when it realizes the PSTN number you called is busy it then sends a 'BUSY' message.
