Call Pickup
mickycollis
Call Pickup
Hi All
There is a new feture on the Voip Portal Called Call Pickup.
I have setup the users that are allowed to pick up the call. I was wondering how the users can pick up the call?
Michael  Crazy
Fixes: 42
Re: Call Pickup
I don't see this facility on my voip portal ?
Fixes: 114
Re: Call Pickup
I'm not seeing it either.
Will Moderate For Thanks
mickycollis
Re: Call Pickup
its on your extension page
I have attached a photo
Fixes: 42
Re: Call Pickup
Nope, not there on mine. Do you have a divert set ?
mickycollis
Re: Call Pickup
Nope
Mines in the bit on account over view then you have
Broadband Phone PAYG 2012-10-10 16:42:41 xxxxx xxxxxx  xxxxxxx (Ext) online until 2013-07-05 14:37:03
Then you hit the Pink extension but and then I go all the way down to the bottom and it says Call Pickup Settings
Mines after the Divert setting and before the routing information
Fixes: 42
Re: Call Pickup
Yes, that's exactly where I was looking but it's not there, see below
Fixes: 4
Re: Call Pickup
I just checked and CAN see it  ?   Huh
[edit:added] on Broadband Phone Anytime 240 from previous legacy account type BBYW-Option#3
RobPN
Re: Call Pickup
Quote from: MisterW
Mine's the same as yours, but I only have Broadband Phone Anytime 240 i.e. the free/included VoIP service which came with certain legacy accounts - maybe it's different for Broadband Phone PAYG?  (unless of course that is what you have)
Fixes: 42
Re: Call Pickup
All very strange! Huh
I have AnyTime 120, which also came with a legacy account.
Call pickup is something I would associate with a multi user ( or extension ) account, whereby you could pickup an incoming call to any phone in your 'group'.
Fixes: 114
Re: Call Pickup
definitely don't have it..
andy265
Re: Call Pickup
I'm on Broadband Phone PAYG and don't have it.
