CSipSimple on Android
gravystuffing
I've managed to set up loads of different soft SIP phones both windows and android but CSipSImple is resisting all my efforts.
Can anyone post the setting they used to make this app work?
Many thanks
Fixes: 44
Re: CSipSimple on Android
In Accounts , add an account as below:-
Account name - Plusnet
Caller ID - <your allocated phone number>
Server - sip.plus.net
Username - <your 7 digit sip id>
Password - <your sip password>
Use TCP - unchecked
Proxy - nat.plus.net:5082
Hope that helps
gravystuffing
I uninstalled it and  started again
Server - sip.plus.net                                                I used sip2.plus.net
Username - <your 7 digit sip id>                          I dropped the leading 4
Use TCP - unchecked
Proxy - nat.plus.net:5082                                        This wasn't needed
and it worked!!!  I'm thinking one of the fields had a extra space at the end entered by mistake.
Thanks for the help anyway  Smiley
