Broadband phone working but cannot select options from voicemail menu
alphatango
My Plusnet Broadband phone is working perfectly on incoming and outgoing VOIP calls (with handset dialling).
I receive message notifications and I can access the voicemail system (using *1) but when connected I cannot select options from the voicemail menu eg 1, to listen , 3 options etc.  Whatever I select, nothing is recognised after the tone is sent and the menu message just repeats several times ignoring all input.
I am using a Camrivox Flexor 151 Analog Telephone Adaptor with a cheap DECT phone from Argos - Magicbox Tachi
I can also access my analogue line using recall, and can then dial numbers with no problem.
Any suggestions appreciated.
Fixes: 41
Re: Broadband phone working but cannot select options from voicemail menu
Not familiar with the 151 but try changing the DTMF mode ( page 44 of the manual http://www.camrivox.com/media/content/file/camrivox_flexor_151_user_manual.pdf ). You can set either InBand or RFC 2833 usually RFC 2833 works better.
itsme
I had a 151 until lightening took it out and from memory I believe what @MisterW has suggested is the answer.
alphatango
Thanks everyone - RFC 2833 worked a treat - your help appreciated.
