Broadband Phone has been shutdown
mattewan
Looks like broadband phone is officially down as of 13:17pm today
Logs from our asterisk PBX:
[Aug 26 12:41:31] NOTICE[12363][C-00003557] Ext. s:  Internal call from "Tracy Davies" <207> to 228
[Aug 26 12:57:49] NOTICE[14149][C-00003558] Ext. s:  Internal call from "PhilR" <230> to 210
[Aug 26 13:17:47] NOTICE[14917] chan_sip.c: Failed to authenticate on REGISTER to '<sip:7930023@sip.gradwell.com>;tag=as425042a4' (tries '3')
[Aug 26 13:18:07] NOTICE[14917] chan_sip.c:    -- Registration for '7930023@sip.gradwell.com' timed out, trying again (Attempt #5)
[Aug 26 13:18:07] NOTICE[14917] chan_sip.c: Failed to authenticate on REGISTER to '<sip:7930023@sip.gradwell.com>;tag=as425042a4' (tries '3')
[Aug 26 13:18:27] NOTICE[14917] chan_sip.c:    -- Registration for '7930023@sip.gradwell.com' timed out, trying again (Attempt #9)
[Aug 26 13:18:32] NOTICE[14917] chan_sip.c: Failed to authenticate on REGISTER to '<sip:7930023@sip.gradwell.com>;tag=as425042a4' (tries '3')
[Aug 26 13:18:47] NOTICE[14917] chan_sip.c:    -- Registration for '7930023@sip.gradwell.com' timed out, trying again (Attempt #13)
[Aug 26 13:18:47] NOTICE[14917] chan_sip.c: Failed to authenticate on REGISTER to '<sip:7930023@sip.gradwell.com>;tag=as425042a4' (tries '3')
Fixes: 69
Re: Broadband Phone has been shutdown
I was given a nod that the suspension script was being kicked off around 1pm, so I suspect it will have finished by now (if not shortly).
Plusnet Products Team
RobPN
Unfortunately it appears that I can now no longer log in to the BB Phone page.  Shocked
I don't think that was supposed to happen as an assurance was given on the other thread that people would still be able to access their phone records to download them for archiving for some time after the service closed.  Huh
Fixes: 69
Quote from: RobPN
That's intentional.
Quote from: RobPN
Ah, I assume you mean the post here? Whilst that may have been the intention at the time, we had to take a different approach due to the way we've chosen to suspend customer's accounts. The records do still exist until the end of September, so if you need copies, then we can provide them on request.
RobPN
Quote from: Bob
Yes Bob, that's the one I was referring to.
I had intended to download all the monthly records available when I had time just in case I ever needed to refer to them in the future.  Oh well, never mind, I can probably survive without them.
Fixes: 69
I don't mind forwarding them to you if you like?
RealAleMadrid
Seasoned Pro
Fixes: 9
Bob,  I had £5.66 credit in my account on 24/8/15, I don't think I've used any credit since then but I can't log into the account anymore to check. I also thought the voip logins would stay active for a while to allow call records to be checked etc but apparently not. As I believe I have over £5 credit so I should be getting an automatic refund, I hope this happens in a timely manner but I'm not confident it will.  Wink
Fixes: 69
Quote from: RealAleMadrid
Yeah, you've £5.66. The refunds will be sent as a cheque in the post to your registered address. You should be in receipt of it by the end of September (probably much sooner).
I still have a dial tone on my VoIP phone, but when I ring my number I get "Sorry, there is a fault. Please try again".
If I try dialling out I get what is probably a "busy signal". I don't use it often, so it isn't a major issue. Just thought I'd mention it...
Robbie
Hi, my VOIP phone went off about the 16th (inc. access to the Broadband phone call page). I never chased it as I knew it was going so switched the phone over to my Sipgate account. I had just over £7 credit on it so I presume that will arrive shortly?
Rob
RobPN
Quote from: Bob
I don't mind forwarding them to you ...
Thanks for the offer Bob, but I'll save you the time by deciding I'll probably not need them.  Smiley
Fixes: 69
Quote from: Jaggies
For some reason, your extension shows as deleted in Gradwell's systems, so I'm assuming the suspension scripts skipped your VoIP account. Probably explains why outbound calls aren't possible. I've just made a quick change that I suspect will kill your SIP registration within the next hour or so.
Quote from: Robbie
That particular problem was resolved the day after.
Quote from: Robbie
Yes, you can expect it by the end of September.
Quote from: RobPN
No worries, let me know if you change your mind.
