Broadband Phone - USA tariff
Fixes: 5
Hi
How much is it to call the USA on Broadband Phone?  I can't find it in the Tariff PDF.  I call a few land lines and mobiles in the USA from Sipgate, but I'm having problems getting Sipgate to work with my new setup, though Plusnets broadband phone is working without a problem.
Many thanks
Phil
Fixes: 113
Re: Broadband Phone - USA tariff
Can't help you with that answer but I use http://www.discountdial.co.uk/index2.php to call the states for 0.5p a min.
Will Moderate For Thanks
puddy
Gradwell who run plusnet voip service charge 1.5ppm
Sky are free
1899 free www.1899.co.uk*
sipgate 1.50ppm landline and the same for mobile
*=1899 is not a voip service you join free and place calls via a normal landline you input 1899 then dial the number
puddy
