Broadband Phone UK Tariff
pd
Hi
Before I tear out any more hair - can someone please point me to the Broadband tariffs for UK calls.  All links appear to point to:
http://www.plus.net/residential/phonecalls/broadband/tariffs.html
but there isn't even a UK selection in the list of countries.
Peter
Fixes: 57
Re: Broadband Phone UK Tariff
itsme
oldjim link above is for PSTN line for UK broadband call tariffs you need to go http://www.plus.net/residential/phonecalls/broadband/ *
Don't forget that most of the BBYW packages have inclusive anytime minutes.
Edit: *and hit the Tarrif tab
itsme
After looking at the Internation tariff price I have to say that the list is a waste of time as the tariffs quoted are 'from' Would it be better to give from and to prices, or even give all the price options?
pd
Thanks both
pd
RichSmol
We should have the full tariff rolled out today so you should be able to get to the tariff (previously this page was accessible through the 'tariff' tab on the Member Centre Broadband Phone pages) from the Credit & Minutes page. I'll let you know when this has rolled.
pd
Thanks Rich.  Will you be looking at my problem today?  Ticket No. 25005944.
Peter
RichSmol
Should be fixed now - for some reason another extension number had been created on migration and was getting in the way. I've removed it and pointed your 84 extension to your PSTN number. You can continue to use the existing username and password associated with that extension.
pd
Thanks Rich, it all appears OK now.
RichSmol
full tariff is now available through the Credit & Minutes section of http://voip.plus.net. ; Cool
pd
That's much better, Rich.  Thanks to all involved.
cluny
The cost of mobile calls (especially 3) seem rather high.  Is there any plans to reduce the cost of them?
RichSmol
yes, this will be addressed soon - we need to stabalise the platform first, build some further backend automation and then we'll look at adding some further functionality and re-assess the tariff in selected areas as well.
danielgmartin
You mention that "full tariff is now available through the Credit & Minutes section of http://voip.plus.net"; but clicking on this does not give the UK tariff details?  They are just shown as blank?  Where can I find them?
At the moment I am being charged approx 16p/min for a call to a Vodaphone mobile is this correct?
