Broadband Phone - Randomly All Calls Going To Voicemail
paxy
I have 2 different broadband phone accounts through 2 different ADSL lines.
Tonight neither are accepting incoming calls and are going to voicemail.
Is there something up with the service?
Regards, Paxy
pnf
Re: Broadband Phone - All Calls Going To Voicemail Tonight??!
paxy
Hi - thanks for the link but I am not sure it helps me.
I can register without any problems and I am already using sip2
I am still having the same problem on both numbers...
Simon_M
You're right - different problem. I'm now registering ok on sip2 & I've just checked that an incoming call does ring rather than go straight to voicemail.
I didn't actually answer it, but I assume that I got further than you are doing.
Two aspirins & if it's not better in the morning, it sounds like a ticket job.  Wink
paxy
Wink
No different this morning so I have raised a ticket.....
farrin
same problem here.......
puddy
yep same problem  10:13
have e-mailed gradwell to find out what the problem is
puddy
James
We've also raised this issue with Gradwell.
Plusnet Staff
Plusnet Staff
as James has mentioned we've raised this to Gradwell. If anyone else has the same problem, could you either post here or raise a ticket and include reference 33997.
This'll make it easier to pull all of the examples together.
paxy
ok - update.
(I have changed no settings on my Grandstream 2020 form when they were working last week)
- Suddenly one account is now ringing.
- The other account has a long silence and then still goes to voicemail.
Both accounts are in the SAME phone with IDENTICAL settings apart from the different plusnet acocunt numbers.
Seems like the problem must be at Gradwell.
paxy
Still the same @ 17:47...one account ringing....one account going to voicemail.......
paxy
Update @ 18:38 - both now seem to be ringing....
Cheesy
paxy
Problem seems to have returned to one of the lines this morning (the one that WAS ringing yesterday).
Any update on this?
Thanks, Paxy
paxy
Back to neither line ringing again this morning.....
Angry
paxy
Another Update
ok - so sometimes it is ringing and sometimes not.  Same results using 2 different accounts.  Tried on Grandstream 2020 and also on SJPhones.  Is there anyone from Gradwell who can help resolve this issue?
