Audio Dropping during call (Outbound)
Probably been posted elsewhere, so feel free to shoot me.
Have made 2 calls this morning, both to PSTN numbers. Approximately 1-2 minutes into the call, the audio drops, resulting in the called party hanging up.
I'm using a Nokia N95 8gb - all set up and been running perfectly well recently, this has just been happening today.
Can someone shed some light on this?
Cheers
Roger.
Fixes: 44
Re: Audio Dropping during call (Outbound)
Roger,
Which outbound proxy are you using ?
nat.plus.net OR the new one natproxy.plus.net.
Try changing to the other one and see if the problem is still there.
Using the nat.plus.net proxy - will try the new natproxy address and see how that goes..
Update...
Made an outgoing call via SIP to PSTN. within 5 minutes, audio dropped out, and couldn't hear called party. This is using the new sip proxy..
Any suggestions?
R.
Fixes: 44
Roger,
You haven't managed somehow to get the 'Wireless power saving' enabled on the N95 have you ? I believe that can cause similar problems.
If that isnt the problem then it does sound to me like a NAT timeout problem. You havent changed anything on your router recently have you ?
Do voip calls from a softphone work ok ? At least that would prove whether its the N95 or a router/proxy issue.
I'm afraid I've no direct experience with the N95 and voip yet , although I'm hoping to get my daughters cast off N95 when she upgrades at the end of her contract next month.
I think Bob Pullen is a bit of a guru on the N95 and voip so it might be worth dropping him a PM and see if he has any ideas.
Just to re-visit this thread Smiley
None of the power settings were set for power saving on the wireless, and it's set for the lowest power setting.. setting it for anything higher drains my battery in next to no time..
Oh.. and all of the ports are mapped in the router (netgear DG834G V4) with most current firmware installed.
/queue Bob..
Fixes: 44
Roger,
If you are using the outbound proxy you shouldnt need any port forwarding on the router.
Try removing it.
If that doesnt help then also make sure the SIP ALG is disabled on the 'Advanced WAN settings' page on the DG834.
puddy
Up todate settings for the Nokia E65 N82 N95 N95-8gb
Sip settings
Profile name  Plusnet
Service profile IETF
Default access point Your router
Public username sip:id number@sip.plus.net
Use compression no
Registration always on or when needed
Use security no
Proxy server
proxy server address  sip:natproxy.plus.net
Realm sip.plus.net
User Name  id number
Password  account password
allow loose routing yes
Transport type UDP
Port 5082
Registrar server
Registrar serv addr sip:sip.plus.net
Realm sip.plus.net
User name id number
Password id password
Transport type UDP
Port 5060
And dont forget this one
tools > settings > phone>  call barring >  internet call barring> anonymous call barring > switch off
If you don’t change the call barring to off, all calls that have number withheld go straight to voice mail
