Anyone using X-lite 5.0.0 softphone?
Fixes: 8
Is there anyone also using this software? If so are you having any problems?
I've been working with Dave Tomlinson for months on the traffic prioritisation which is sticking the VoIP traffic in to bronze.
Call quality is at times very poor. I'm also seeing  the phone lose connection with the server several times a day (when not on a call). Two or three times a day it drops out in the middle of a call.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 41
Re: Anyone using X-lite 5.0.0 softphone?
Sorry, XLite 5 ain't supported under Linux so I'm still on 3.0 at home.
I thought prehaps I would try it in the office but when I try to install it says it needs to install 'Visual C++ 2010 SP1' Shocked
@jelv, Does it really mean that , or is it just the VC 2010 runtime it is going to install ?
I just don't want it to mess with my existing Visual Studio Installation
Fixes: 111
i can install it on one of my Macs, to see if it drops but I don't have a headset to test it.
Will Moderate For Thanks
Fixes: 8
I've looked in Control Panel Programs and Features - I have a number of Microsoft Visual C++ 2008 Redistributable entries + one 2010. Looking at the installed date I'm guessing it's just the 2010 one needed and the others are from earlier installations.
Fixes: 8
This still hasn't been fixed and at times the call quality is bordering on the unusable - not surprising when calls are in the 0x00 bronze queue.
How about an indication of when this is going to be fixed please?
RPMozley
Hi jelv, update for X-lite has been released. Weirdly it's version 4.5  Shocked how odd.  Cheesy
Fixes: 8
Be careful if you 'upgrade' - it wipes all your settings and looses all your contacts. Grrrr! Sad
