Anyone else having registration issues?
Fixes: 116
Been using my softphone happily this morning but it seems to have dropped off and won't register, anyone else having issues?
Will Moderate For Thanks
Re: Anyone else having registration issues?
Yes. no service here either
glloyd
Looks like it's gone belly up again.
Fixes: 43
Just ran X-Lite here ( in the office ) and registered fine!.
voip portal doesn't show my C475 online at home though...
Just called home from X-lite here and my C475 answered , so it was still registered.
Voip portal probably just confused with me starting and stopping X-Lite ( it seems to unregister when you exit ) unlike some other softphones!
Fixes: 43
Portal now showing C475IP expires at 14:28 , so must have registered at approx 13:28...
thehatman
I'm getting dropped calls recently.
pnf
I made a call this morning which got cut off after about 1 minute.  I made subsequent calls via PSTN as I didn't want to risk those calls getting terminated.
Fixes: 43
My C475 failing registration here this morning, last registered about 10:20 ...
puddy
My Siemens C460 reports sip registration Failed
puddy
Fixes: 43
Mine's registered again now , BUT now cant see voip.plus.net!!!
Page just says 'Cannot connect to database [voip]'
Obviously Gradwell haven't sorted the problems earlier this week.
'service status' update is overdue!!
puddy
Mine are all working now but I had to re-boot all my devices
Time 13:49
puddy
