Any ideas how to set up SJPhone on a Mac?
kevandali
Hi All
I have sucessfully got SJPhone working on a non wireless PC but want to get it to work with my Mac as it has a built in speaker and microphone and can use it till I can afford either a phone or an ata adapter.
Can't see how to configure it
Cheers
Kev
Fixes: 113
Re: Any ideas how to set up SJPhone on a Mac?
TBH I wouldn't bother, it's quite woeful on the Mac,
I use zoiper, http://www.zoiper.com/, much better.
Will Moderate For Thanks
kevandali
Cheers for the reply, have managed to set it up but will the voiper software work with my broadband plus net account and if so is it just a case of adding the same setings?Huh
Cheers
Fixes: 113
yep, I use it everyday on the PN voip Smiley
Settings should be the same
kevandali
Great, will give it a go, Thanks------ do I download the latest verson 2.09?Huh
Thanks again for the help
Fixes: 113
I've attached a screen shot of my settings to help you along the way..
kevandali
Sorted, Cheers
