Any chance of an updated how-to for SIP on the Nokia N95 etc?
Rikaitch
The old post is now out of date as far as I can tell (it uses sip.plus.net, not sip2) and I can't get my Nokia N95 to work on SIP. A simple guide would be really useful.
Fixes: 69
Re: Any chance of an updated how-to for SIP on the Nokia N95 etc?
Here are the current settings I'm using behind a BT Voyager 2091:
Tools > Settings > SIP Settings
Profile name: Gradwell.
Service profile: IETF.
Default access point: Home Gateway (this is the name of my wireless access point).
Public username: sip:1234567@sip.plus.net (where 1234567 is your SIP ID).
Use compression: No.
Registration: Always on.
Use security: No.
Proxy Server
Proxy server address: sip:nat.plus.net
Realm: sip.plus.net
User name: 1234567 (where 1234567 is your SIP ID).
Password: Your VoIP password.
Allow loose routing: Yes.
Transport type: UDP.
Port: 5082.
Registrar Server
Registrar server address:
sip:sip.plus.net
Realm: sip.plus.net
Port: 5060.
Plusnet Products Team
puddy
Both settings work sip2 and sip but which are the correct settings we are supposed to use now?
puddy
RichSmol
sip.plus.net is preferred. There are no plans to consolidate the settings to sip.plus.net.
Fixes: 69
Yep, they both point to the same place:
bpullen@pvs-csctools:~$ host sip.plus.net
sip.plus.net has address 79.135.125.155
sip.plus.net has address 79.135.125.154
bpullen@pvs-csctools:~$ host sip2.plus.net
sip2.plus.net has address 79.135.125.155
sip2.plus.net has address 79.135.125.154
Fixes: 111
Thanks very much for that, my N95 seems to be working well now  Smiley
Will Moderate For Thanks
