ATCOM AG168v - Config help needed
rocca
Hi
I've configured my Atcom with the settings on the attched pic but i can only seem to make calls, when i try calling the direct dial no. i just get a dead tone.
anyone any ideas what i might have wrong ?
I have ports 5060 & 5082 forwarding to it on the router.
tia
Fergus
1 REPLY
Fixes: 44
Re: ATCOM AG168v - Config help needed
I think you may need the 'Nat Traversal' set to enable for incoming calls to work according to this post
http://www.voip-info.org/wiki/view/AG-168V
