50p calling credit
eattheword
50p calling credit
I configured my new VoIP number yesterday and can receive calls on my iPod and iPhone using 3CX. However, when I tried to make a test call it refused. When I logged into the VoIP control panel I see that the call was barred because of insufficient calling credit. But the email I got welcoming me to the service told me I have been given 50p calling credit (presumably so that I can test the configuration). My control panel shows £0.00 balances for calling credit.
Does this 50p credit take a while to show up, or have they just forgotten to give me it?
Fixes: 43
Re: 50p calling credit
Normally, credit takes upto 24 hours to apply.
eattheword
Hmmmm....
It said this: "You'll need some credit to make calls so we've given you 50p of free credit so you can get started straight away" in an email time stamped "26 April 2012 20:46:25". I'll wait till Monday and see if anything shows up.
Fixes: 43
If you want to test making a call without credit you should be able to make an IP call ok. If you connect both the Iphone and IPod at the same time ( yes you can have multiple devices registered ) then you can call 'yourself' by calling your extension number. I use that facility when I'm away from home and have Wifi available, I just run a softphone up on my netbook and call home for free. Note that when you have multiple devices registered they all ring ( which can be confusing on the one you're calling from! ) and the first to answer will get the call.
jojopillo
HI eattheword,
I've someone looking into this for you. It should have been added but isn't showing up for some reason. I'll let you know when I know more.
Jojo Smiley
eattheword
Thanks, Jojo!  Smiley
dick:quote
jojopillo
HI eattheword,
It should be on there now.
Jojo Smiley
eattheword
Thank you. I'll go and phone someone now to test it out.  Cheesy
sitre83
I've got the same issue with my setup (purchase date of 03/05/2012), but free starter credit hasn't shown up  Sad
Si
jaygee
I'm in the same position - no show of 50p credit to check functionality. Is there a technical problem ?
jojopillo
Hi SI, your 50p was added on the 3rd.
HI jaygee, I've just added your 50p, you should be able to use this now.
Jojo Smiley
HartPD
I also have the same problem - Its been three days since the Broadband phone was enabled and I don't see the 50p.
The phone works fine IP to IP, and I would be happy to buy more credit, but the credit details section is missing from the Control centre.
Paul.
Gigaset N300IP
jojopillo
HI HartPD,
Sorry we never picked this up at the time. I see this has been sorted via ticket now.
Jojo Smiley
