3CX won't make outgoing calls
The_10th
Have installed 3CX on Android Samsung Galaxy Ace and configured it and says On Hook but only receives calls. When making a call it goes straight to On Hook. I suspect a software bug with the version 1.3.3 of 3CX but just want to know if anyone has a solution to this problem?
The_10th
Re: 3CX won't make outgoing calls
Removed this application and tried CSipSimple instead and used the 'advanced' option to configure.
itsme
My 3CX has stopped working since I updated the application 2 days ago running on an ipod touch. Have not had time to investigate why.
The_10th
Recommend CSipSimple - small download and nice interface.  Smiley
