3CX Settings for Iphone please
nortonhall
Hi
I have installed 3CS on my iphone and i do not have all the settings needed to make it work. Ihave the user id and password and proxy but not sure about the others. Does anyone have whats needed please?
Ian
RPMozley
Re: 3CX Settings for Iphone please
Hi Ian,
See my reply to this thread for the settings, although now I've found out that it's best to use the 'External PBX' & 'SIP account' rather than 'In Office', when 'roaming' and not using your PN connection.
Regards,
RPM
nortonhall
That did it, it works now but a bit too quiet for the caller I recieved. It also did not work from callers mobile only their landline, i am sure this is my innocence but do you have any advice?
Regards
Ian
RPMozley
Umm... I'm not sure why it would be like that. I'm afraid I don't really have much usage experience, so can't really give you any other points as to settings.
Maybe someone else might know about this issue? Undecided
