xbox
xbox
I'm planning on buying an Xbox and using the Xbox live, but I've heard a few ISP's aren't compatible with it, most notably AOL.
So anyone know if it works, or tested it?
espresso_mick
RE: xbox
http://forums.uk2.net/showthread.php?s=4ecc310f1fa6fa9375b6b072e583c08e&threadid=19866&highlight=tes...
Saw this thread not long ago on UK2 forums. Read the comments by <=SAS=>HoDgE ,who has it.
RE: xbox
This is what +net cs said 4 days ago about connecting the x box.
http://portal.plus.net/central.html?action=new_forums&forum_action=display_topic&topic_id=5491&messa...
Its amazing how the same questions keep on getting asked when all you have to do is use the search to get your answer.
