xbox - Dynamode usb modem
Hi There,
Do I Really NEED an Ethernet router modem to connect the Xbox. I have 2 Realtek network cards and the Dynamode usb modem. Is there a way of configuring this setup under WinXP Home??...
I can't install the config software for the modem as PPPoE is there a workaround?
Regards
Neil
Moderators note by Chris: Please don't cross post in two forums, it confuses other users.
Nope, you will need a router.
Chris
I thought you could use ICS with the X-Box? I may be wrong though.
ics Huh
Windows Internet Connection Sharing. Smiley
Thomas
ICS is, as Thomas rightly said, Internet Connection Sharing. It's a way of allowing multiple Windows-based computers to access the internet at the same time. More details are available on the Microsoft Support Site.
Though I may be wrong - this may not work with the X-Box, I have no experience of this.
Thanks for all your suggestions - no joy connecting though. Now have an ADSL router and no problems...
