xbox 360 Live & NAT problem
I've been on live for ages and today after not being able to play with a friend realised it was down to my NAT being set to moderate. I've tried opening the suggested ports for live and setting the dmz to forward to the 360, but it still comes up as moderate.
I'm using a BT voyager 240 router/modem - any tips?
first tip : give the 360 to me
2nd tip : try to make sure you have all the TCP and UDP ports forwarded to the xbox that are needed, you should not need to set it in a DMZ
Delves
Are you using DHCP, It could be that your 360 is getting a different IP each time you switch on. I ended up giving mine a fixed IP.
I also had this problem to fix it i did the following:-
1) assign a static ip address to your xbox 360
2) set the following ports to forward to the ip address you gave to your xbox
Port 3074 TCP and UDP
Port 88 UDP only
Regards
James Russell
