woosh test results
woosh test results
what does this mean for me,what speed is my line going to be able to use?
xDSL Status Check OK
Circuit Information
Circuit In Sync
Upstream xDSL Link Info
Loop Loss 30.5 dB
Cell Count 362854
Downstream xDSL Link Info
Loop Loss 48.5 dB
Cell Count 838437
woosh test results
With current BT rules you cant really support 2MB but this may change from april.
woosh test results
And anyone decipher these results (sorry if i'm hijacking the thread, thought it better to keep in one)
The results are as follows ...
xDSL Status Check Not in sync - suggest cct reset and line test
Circuit Information
Circuit NOT in Sync
Loop Loss n/a
Cell Count 54
Loop Loss n/a
Cell Count 67
woosh test results
For some reason it looks like your modem or router wasn't connected or switched on when the test was done.
Andy.
woosh test results
Loop Loss 23 dB
Cell Count 12456951
Loop Loss 38 dB
Cell Count 84656715
good? bad? ok? Cheesy
woosh test results
38db line attenuation is currently ok for 2mb but thats probably going to change in the future anyway (i.e. you may be able to go faster). But you haven't got any SNR/margin figures there. You really need those figures too as anything below 12db SNR (approx) could cause problems at any speed.
Andy.
