wont shut down since adsl
as soon as i installed plusnet adsl on my pc win xp will not shutdown,i formatted c drive and reinstalled thinking xp had ballsed up but after reinstall adsl same problem.help please it is definately the connexant software causin this problem
tried all other software conflicts read about
athlon xp1800+
k7s5a mobo(sis 735 chip)
geforce 4 ti4200 128 mb ddr
512mb ddr ram
win xp home ed
maxtor 60gig hd
RE: wont shut down since adsl
Have you downloaded the latest drivers for your modem? This should fix the problem.
> athlon xp1800+
> 512mb ddr ram
> win xp home ed
> maxtor 60gig hd
> athlon xp1800+
> 512mb ddr ram
> win xp home ed
> maxtor 60gig hd
Hi
Is it a USB modem? and do you have any other usb periphals connected? I have very similar spec to you, found a problem with the USB ports on k7s5a most things connected to it will cause XP(why did I bother!) to hang. Still haven`t resolved the problem though, so any help would be welcomed too. The computer does shutdown but the "shutting down" screen remains, just won't power off. Works fine under Win98 so my guess is a USB driver is needed for XP, but I haven't found one yet :-(
sorry
doozer
jlpappin
XP randomly powers off. Microsoft removed something because with previous OS it could not perfect the art of actually making the PC switch off. So all PC's can make it to the black screen with "you may now switch off your computer" but not all will power off.
As for the modem, which one you using? I use Alcatel Speedtouch USB and I make it to the power down screen fine but then I have to manually turn the PC off.
im using the internal pci modem supplied by plusnet
it is a conexant adsl wan adaptor
where can i find new drivers?
thanx lads
Andrew
what experts we are detecting a USB problem ;-0
try this link, make sure you select the right modem.
https://portal.plus.net/supportpages.html?a=225#drivers
regards
doozer
tried the new drivers but to no avail,even tried the newest driver from conexant
cant keep turnin off pc by killin power!!
thats just askin for trouble.
ps. if i uninstall modem then problem goes but then i have no modemSad
Andrew
Did you manage to resolve the problem of xp hanging during shutdown?
i'm still experiencing same difficulties, and keen to resolve
cheers
al
